how would you start to determine sizing of equipment at intake ie:
size of main fuse, Legally you can't as you would need to see it to be sure. Most cutouts that I see, although labeled as having a 100A 1361 II, have a 60A or 80A - if you look at the meter it usually has a current rating on it, the main fuse is likely to be the same or smaller ----- if you ring the DNO, they won't know and they are unlikel;y to send someone out to confirm it's rating
meter tails If you are having a problem with cable sizes then try using offcuts to compare - otherwise most of us can tell a cables size just by looking (experience)
main earth Same as above
never had opportunity to look into this and im puzzled
