B
Bambergaspipe
SPELLING.........YOU DIVVYHE KNOW HAS TWO PROBLEMS
Sorry, fanx for pointig that owt mate.
Sorry, fanx for pointig that owt mate.![]()
Happy Hard on.
Idiosyncratic lunatic.................you should try to get out more instead of
coming out with a load of guff
CORGI Reg No 191282..................WTF is yours............C'mon don't be shy GOBBY![]()
Did i say that your diagnosis was incorrect.
As already pointed out ,pilot injector is now probably blocked after a poor attempt at cleaning,original problem could well have been T/C on way out,this will be verified when pilot injector is correctly re-established.
AS for multipoints , have fitted many britony 11T's,,Main medway,mersey,trent ,avon and many moons ago the odd G/W Ascot![]()
the pilot staying lit, cured it by cleaning the jet
Eh did you miss the bit where he said had cured pilot out by cleaning it
He had a problem with the pilot staying lit, probably thermocouple, he has now cleaned the the jet, he know can`t fire up the heater, I assume he is not a fitter and unused to servicing water heaters he has probably blocked the pilot injector, he now has two problems instead of his first problem. What do you think Sherlock?
