K
kai
No you can't, as BS7671:2001, states that no switch or similar shall be placed in the Earthing Conductor.
You do not isolate the earth with any switch in a fixed installation normaly and thats why most switches are double pole!!!!I haven't got the regs here but certainly isolators, and, of course plug/socket as means of isolation, working on all 3 poles are common, but no one, as far as I know makes RCDs that do this.
Just to clarify if you run a supply from a PME fed house to ,say, a shed/garage do you use the pme earth or bang in a rod.
Well, tangent or not, the point is that if you don't have a TN-S supply you can't use a "TN-S method" to provide an earth for your outbuilding, with or without permission. The discussion that arose was around the contentious subject of exporting PME earths. I agree that if you have a TN-S supply then use the earth from that.mingmong said:Its interesting how its gone off on a PME tangent this topic.
The majority buildings are underground cable fed, protected by a metallic sheath/armouring, so why not use the TN-S method? and use the supply companys cable armouring.
(with their permission of course!!)???![]()
If what I read somewhere is true, however, I wonder how many people who think they have a TN-S supply actually don't, because the armour of the cable has rotted away.
