Mains feed supply
17 Feb 2008
Berkshire
If the mains to Megaflo is isolated, is it OK to cut pipe here to fit valves for water softener no water will come back up pipe?
Isolate the mains and then open a HW tap(s) to release any pressure. The combi valve has a check valve so there shouldn't be any backflow but just in case. The only issue you may have is from the balanced supply that's heading out right from the combi valve in the pic, as it's heading upwards you may have to empty that.
