Mains Tap
11 Jan 2006
Does anyone know how to unstiffen a tap that wont budge?
Cheers
Waxoyl from car accessory shops is my choice. You have to put it on then leave it for about a week to penetrate. Heat might shift it.
By mains tap do you mean the a outside stopcock or a inside stopcock or the kitchen tap all are on the mains.
If its a stopcock then it will be open and should only be turned clockwise.
You could make it a little easier by unscrewing the gland nut.
If it's the inside stopcock and you can turn off the outside stopcock, then it is easier to remove the tap head from the body, then you can use heat or penetrating oil. Is your outside stopcock just for your property.
:roll: :roll: :roll:
PEDANTICVINDICTIVEMAN
Why this big sarcastic chip on your shoulders.Maybe you need a good flush.
