Im having a mains water line installed and its in plastic. I worried rats may chew through within the suspended floor area hence i have a couple of questions for you very helpfull people.
1. Can a mains water pipe be run above ground from inside house to boiler. Boiler would be approx 12 meters away from the point of the pipe being above ground if not then why not, and if yes are there any disadvantages?
2. Do rats chew through these pipe?
3. If i pressed on and installed the bluse platic pipe below groung but i ever had a problem in the future can i re route the pipe above ground as i wouldnt want to take up the kitchen concrete floor.
