Making a chamfer
  • Thread starter Thread starter marsaday
  • Start date Start date
M
marsaday
I am renewing a section of my facia and have cut a piece of wood 230mm wide and 30mm thick. It is 1m in length
30mm from the bottom the wood is cut so it goes inwards by 15mm at the bottom. I think this is called a shampher.
Does anyone know how i can do it?
i am struggling and i may juts take it to a joinery workshop. If i do how much do you think they will charge me?
I think you are referring to a chamfer, which is basically a bevelled edge usually at 45 degrees.
It is really easy to do with a circular saw set to cut at 45deg. Mark your line parallel to and the desired amount in from the edge and run the saw along.
Done.
