Making a cupboard door
12 Feb 2010
Norfolk
I need to make a cupboard door; 600 x 600 and about 30mm thick.
I guess I will use battens and glue/tack board to either side of the batten.
What do I use as the board? ply?
Thank you.
Why don't you just make the door out of a single piece of MDF?
Can I get a peice of MDF that thick?
Also, isn't the edge of MDF easily damaged, it doesn't appear to stand up too well against knocks.
What are the style of the other doors around the gaff?
If astheticly pleasing would it be ok to make up a door out of wood O.o (matchboard even?)
You should find 18mm mdf perfectly adequate, it is stronger than a conventional hollow door and very easy to repair damage on.Paints up perfectly flat.
That small you could make up a pair of draws to fit under and hold the shoes.
I really appreciate your help, but I don't want to use MDF.
If I use battens to make the door, what timber should I glue each side? Ply?
Thanks.
