For whatever reason (either I gave the wrong code or I lost my mind when I measured), the new external door that I ordered is shy some 40mm wide and 20mm high of the door frame.
The question I have is ... Can I make the door frame smaller to fit the door?
The door is 762x1981mm
The frame 810x2020mm
I'm so annoyed with myself I feel like banging in a couple of lengths of 2by1 and have done with it.
However, I'm liittle concerned if I add to the frame whether it will support the weight of the door.
Someone else suggested that I should add to the door but I am reluctant as it would void the warranty and I'm pretty sure it would be noticible.
What do you folks think?
Any suggestions about the type of wood + dimensions and how it should be fixed, would really be appreciated.
