Making good missing area of paint on ceiling
17 Sep 2011
Hampshire
HI to all
When painting my kitchen ceiling with emulsion, a patch of paint peeled away. I waited for things to dry then scraped away any other loose paint around the area(now about 250x250mm) and bonded it with an oil based primer. I was using a thick emulsion and was hoping that it would cover and blend in the missing paint but the patch is still visible :( Does anyone know how to get over this without having to strip off all the paint to the same level.
Any advice/help gratefully received, thanks.
When this happens it is an indication that the underlying paint system has failed to bond with the surface/substrate, and there could be a number of factors of which could be involved. At this time a pic could prove useful, the application of a thick coat of paint will only highlight the problem.
If your problem at present is confined to one single area you should try sanding back the area to try and achieve a uniform finish yet if this alone proves to be difficult you will need to face fill and then lightly sand.
Dec
Thanks for the reply The Dec. I gave the edges of the offending patch a good scrape and removed all of the paint that was going to come off without resulting to more extreme measures. The paint around the edge appears sound so it's just a case of how to achieve the "cosmetic" finish.
