We currently have a built in cupboard (1950s terrace house), the right hand half is made of two timber doors 6ft high but the opening goes beyond the doors to the left where there is just a wall, basically the doors only give access to half the total cupboard space. The ceiling is 7'7" high.
To utilise the space better we want to knock out the whole width of the space which is about 1.7metres wide, and after i want to have a single frame with an internal curtain.
I know that the wall is made of blockwork - the horrible black ones which are very crumbly, and the top part above the door height is stud wall type.
What is the best way to make the opening, retaining the stud part ontop?
Do i need a slit cutter to cut the blocks, or can i knock it out with a hammer and chisel? Bearing in mind i want as little dust as possible.
Will i need to prop it considering its non loadbearing?
thanks - ps i'm a very non experience DIYer when it comes to bricks and walls....but I'm good with timber.
