    Dismiss Notice
Makita 18v 2.6AH NiMh batteries
Discussion in 'Tools and Materials' started by WithamWonderer, 20 Oct 2009.
  1. WithamWonderer
    WithamWonderer
    20 Oct 2009
    5
    Thanks Received:
    Lincolnshire
    Country:
    About 3 yrs ago I purchased a Makita combi drill with 3 x 18v 2.6AH NiMh batteries. I have been careful to treat the batteries properly, always fully discharging before fully recharging and using each of the 3 batteries in sequence. Within the last 2 weeks all three are now reporting as broken batteries when I try to recharge (lamp on charger flashes red / green continuously). Prior to this all 3 were working well and holding charge. Does anyone else have experience of this and better still know why it should happen. Its as if those nice chaps at Makita had built in something to say stop charging this cell after 3 yrs or so many charges.
    Anyone know of a fix or do I have to fork out for a new set of batteries @ £60+ a pop?
  2. Sponsored Links
  3. Bodgeit and scarper ltd
    18 Jun 2007
    476
    Thanks Received:
    2
    Cornwall
    Country:
    check the charger is working
  4. WithamWonderer
    WithamWonderer
    20 Oct 2009
    5
    Thanks Received:
    Lincolnshire
    Country:
    I've no reason to believe that the charger is faulty as after the 1st battery failed the 2nd and 3rd still charged and then the 3rd still charged after 2nd failed.
  5. WithamWonderer
    WithamWonderer
    20 Oct 2009
    5
    Thanks Received:
    Lincolnshire
    Country:
    might buy a MTX with a couple of 2.6AH NiMh batteries + charger (currently offered around £140 + tax at local merchants) that way I'll get a spare drill & charger for little more than a couple of batteries.
  6. big-all
    big-all
    12 Jul 2004
    17,756
    Thanks Received:
    1,335
    Surrey
    Country:
    if you look at what happening logic dictates you must consider the charger as a possibility because its the only common denominator with all the failures
    for example chargers are often temperature sensitive as can be batteries so you have attempted to charge a hot battery or in a hot area
    other possibilities is its an intermittent fault with the charger that happens at the whim off the gods
  7. gregers
    gregers
    28 Mar 2008
    6,301
    Thanks Received:
    499
    Sussex
    Country:
    i had a mtx and both batteries died on me within 18mths or so,and those too were drained every time and recharged as per instructions,ive now got a bosch ion drill and i must say its bl00dy good.
  8. DIYnot Local
    3 Sep 2019
    Country:
  9. Sponsored Links
Loading...
Share This Page
