- Joined
- 27 Aug 2022
- Messages
- 2
- Reaction score
- 0
- Country
I moved into this property around 18 months ago. 1930s semi with a small kitchen extension to the rear which backs on to the garage to the front. There is a door between garage and kitchen, with the garage level two steps down.
Recently I noticed a bad smell so checked out the manhole cover out on the patio and surely enough it was backed up. I tried to hose and drain rod which to my huge surprise resulted in drain water leaking out into the garage.
Further investigation has revealed there is another manhole cover under the kitchen extension the corner of which is just barely visible via the stairs the drop down into the garage. It was here that water was overflowing. The stairs seem to drop to the ground level, level to the top of the cover. But there doesn’t appear to be a proper cover in place.
Turns out that whoever built the extension or the garage access has half exposed the old manhole and not sealed it up correctly. I’m at a loss as to what to do here.
It would seem I now need to rip up the entire kitchen floor to have full top down access to the manhole to replace the whole manhole with something fit for purpose.
Either that or is it possible to somehow fill in the manhole altogether? It has two inlets, one from the soil stack, one from the garden manhole and one outlet which runs into the street so could you add a top to the drain and fill it in?
