I am replaclng a ceiling fan with a Manrose Fan with timer and shutters.
Model Manrose SPE100AFTS double insulated no earth connection required.
I want to use a lighting circuit junction box in the loft for supply.
I want to use the existing Double Pole 16 amp ceiling pull switch for the switch.
I want to use a Double Pole FCU with 3 amp fuse fitted.
The diagrams show terminal positions of each item; Fan, Switch, FCU, Junction box.
Questions:
How should this be wired to show the Neon indicator lit only when switch is ON.
In simple terms; which wire goes to which terminal; a diagram would be appreciated a picture is worth a thousand words.
I have wired the circuit successfully and the fan works ON/OFF OK but...the timer does not operate; hence the wiring is not correct.
Thank you
Questions:
Thank you
