- Joined
- 5 Feb 2020
- Messages
- 2
- Reaction score
- 0
- Country
Hello,
I've recently moved into a house which has a wet room. There's a small window which can be opened quite wide and a small heated towel rail which doesn't get very hot.
After using the shower, I always leave the window open for about half and hour and leave the extractor fan running for as long as I can but the wet room has recently started to gain a slightly musky smell and black mould started forming in the corners of the ceiling.
Yesterday I had a larger towel rail installed which warms up the room better and had a Manrose remote humidistat installed but I cant work out the RH%. I had it set to 70% last night and the fan started working soon after the shower was turned on but it switched itself off about a minutes after I finished. Does the lower % mean the fan will run for longer? There is also a timer on the Manrose but as its on a pull cord, I believe its overwritten. Also, should I leave the window open or keep it closed?
