Does anyone have a preference of manufacturers? My Honeywell is playing up and will need replacing soon. Seems to me that Honeywell valves don't last that long as I'm on my 3rd one.
Are you sure it's not an electrical fault with your wiring causing them to fail? I use Honeywell all the time and haven't had any issues...although you don't say how long each of yours have lasted
It's definitely mechanical. When I remove the actuator head, the shaft rotation feels rough and stiff to turn by hand. I've tried exercising it and it works for a short while but eventually it stiffens up again. I've had a total of three valves fitted in the space of 20 years or so. Maybe I'm being unreasonable in my expectations and changing them every 6 years or so is normal.
Depends on how many rads you have. For a standard size system. (no more than 15 rads). I charge £450. But that's to do a proper job. Full chemical powerflush using powerflush machine and magna cleanse filter and a radiator agitator. Properly balancing the system Plus adding inhibitor. Full days job on a bad system.
