Mapesil AC on Multikwik connector
29 Aug 2011
Leicester
Hi.
Whats the difference between Mapesil AC and other Sanitary Silicone sealers?
I have applied Mapesil AC to a Multikwik connector, but it peals off if you rub it. Should I use Mapei Primer FD or another Sanitary Silicone sealer?
Any help is appreciated :?
Try a tube of Fernox LS-X , I`ve had good results with it on existing multiquiks that leak , and you don`t need to try and get a mastic gun in @ the joint :idea:
I've used LS-X for a temp repair before, didn't expect it to work, but it was great. Lasted the 3 days until I got the part. Think it would have lasted forever
I don't actually know if it leaks yet. It just seems strange that the Mapesil sealer peels off by rubbing it.
It`s because it`s not neutral curing silicone :idea: did it smell of vinegar ?. If it did it`s acetoxy silicone and won`t stick well to plastics , commonly sold - But you have to search out N.C. silicone for a proper job
Is there a need for sealant?
Unless you are using a Multikwik at quite an oblique angle the flexibility of the fins should seal enough on their own.
With all the angles and offsets available something should fit well enough to negate the need for sealant.
