Hey all,
I have hired a digger next week to dig my extension (39m2) foundations so I need to mark out - I will give my thoughts below but if anyone has any advice it would be appreciated.
1 - Going to secure short battons to existing wall where footings will be required and then add nails in the center and outside of where footings are needed.
2 - Will do the same the other end of wll but using some profile boards (two stakes with a cross member)
3 - I will ensure everything is square using the 3-4-5 method as well as running a line down the side of the house and measuring diagonals..
4 - I will then run a line across the nails and use a level to mark footings position and mark with spray.
5 - To get the right height for the bottom of the foundations I was going to create a datum inside the new extension at same height as current floor. From this I will work backwards with bricks/blocks/mortar/foundation depth so that I shouldnt have to cut any bricks/blocks.
Does this all sound about right? I will plan on using the same method to set out for the blockwork.
