Masking tape is tearing paint off
30 Mar 2015
Before painting a wall, I loosened the sockets and switches and then taped their edges with masking tape.
I painted silk emulsion on the wall and there must have been some contact with the tape. When I went to peel the tape off after the second coat, the paint started peeling.
Should I not be using masking tape in this situation or why is this happening?
I assume I now need to use filler and then sand and paint again? Is it okay to patch this given that I am using silk emulsion?
Thanks in advance.
Always remove tape as soon as you've painted. Once you let the paint cure it forms a film over the tape edge thus removing the tape also lifts the paint on the walls.
If you ever forget to remove the tape run a sharp knife along the tape edge before lifting.
Yeah depending how much has come off rub down the paint edges, clean off and repaint.
I was conscious that the tape needs to be removed as quickly as possible but I was unable to do this until the second coat was applied...
Will bear your tip on stanley knife in mind for the next time.
Am I okay to patch repair and paint silk in this way? I know with Matt its not a issue but I didn't know if silk will blend in or whether the brush strokes will show up. I will feather them out as best as I can. Can you provide a steer on this please.
Thanks for your help.
If I'm using tape I always put a good first coat on then whip the tape off straight away. On the second coat I cut in by hand but you've got a nice straight edge to work with.
Silk is always harder to get a good finish especially patching in but you'll be fine doing so presuming the stripped paint hasn't gone back to plaster. If so give it a good run down to feather out the remaining painted edges, clean off, mist coat then apply your silk.
