    Dismiss Notice
Matching existing concrete
Discussion in 'Building' started by MorphDoc, 24 May 2021.
  1. MorphDoc
    MorphDoc
    24 May 2021
    2
    Thanks Received:
    Country:
    Hi folks,
    Fresh home owner here and DIYer who is trying to save some cash
    I built a path at the fron of my house but now I need to fill the gap between my path and the existing concrere driveway. I know it will be difficult to match the colour but I would like to at least try to get similar look. The house is from 1955, so I guess the driveway must be similar age.
    Here it is:
    [​IMG]
    https://imgur.com/a/SFSnV71
    and here is tje gap
    [​IMG]
    http://imgur.com/a/2woce01
    I think it has pea gravel in it, but I am not sure what mix to use. 1:2:4 (cement:pea gravel:sand) or different ratio?
    Thanks for advice :)
  2. Sponsored Links
  3. MorphDoc
    MorphDoc
    24 May 2021
    2
    Thanks Received:
    Country:
    anyone?
  4. lostinthelight
    lostinthelight
    11 Feb 2016
    3,063
    Thanks Received:
    588
    monmouthshire
    Country:
    Colour will vary by stength of mix,brand of cement and type of sand/aggregate so match us difficult to achieve.
  5. Harry Bloomfield
    Harry Bloomfield
    30 Dec 2018
    6,931
    Thanks Received:
    999
    Country:
    My limited experience with concrete suggests a match will not be easy. When you tamp and smooth it down, the pebble will naturally go below the surface, so I would be looking to..... Tamping, smoothing and allowing it to partially set up, then scatter some suitable sized pebbles over the surface and partially tamping them in.
  6. lostinthelight
    lostinthelight
    11 Feb 2016
    3,063
    Thanks Received:
    588
    monmouthshire
    Country:
    Here you go:
    • Thanks Thanks x 1
  7. JohnD
    JohnD
    15 Nov 2005
    72,825
    Thanks Received:
    4,168
    Crossgates, Europe
    Country:
    Cook Islands
    I can't see your photos
    (You can can add pics to your reply by copy and paste, or with the "upload a file" button)
    It sounds to me like you want an Exposed Aggregate finish to match old, worn concrete.
    This can be done by hosing and brushing the surface after initial set. Try a goggle search for videos.
    Edit
    Too slow!
  8. Sponsored Links
Loading...
Share This Page
