Matching skirting board
2 Feb 2024
Hi. Im trying to match some 1930s skirting. 1st and 2nd pics shows the original which I think is lambs tongue. There are plenty of sites offering new lambs tongue but the profiles differ quite a lot between different supplier and none seem to be as per my original stuff. Ive managed to find a near match (3rd and 4th pic) you can see that the new stuff does not have the extra lip at the bottom of the profile. So my question to any experienced wood people is would it be possible to cut a small notch into the new stuff using a bench saw set at the correct depth. Ive marked this in black on the new sample. If its possible to do this it would make the new skirts look much more like the original stuff. Any advice is very much appreciated
the trouble you have is on a table saw it will be a square step and at 3.2mm1/8" blade looks like you will need perhaps 3 passes that adds to the possible wibble wabble [highly tecnical term] possible with the weight and bend off the timber varying the exact path off the timber/board along with repositioning hand pressure as you go may give you possibly up to 3 separate slightly different steps or grooves
what lengths are you talking about??
options are replacing the smallest room or cupboard with new and use that
other solutions is in cupboards including fitted kitchen or bath hiding usable lengths
