max size extension without planning permission
20 Apr 2014
I understand that I can build a single story rear extension to my semi without obtaining planning permission. The extension has to be under 70m3, but I have had conflicting reports on whether or not I have to include my porch in the 70m3.
Any ideas?
are you building a new porch at the same time??
It is all down to "permitted developments". many local authorities have a "pd enquiry form" or similar service which is free of charge and basically fill this in and they will tell you if it is allowed or not.
Basically (if you are doing both) they are both seperate permitted development and therefore are seperate to each other. The maximum size for a porch without planning permission is 3m2 floor area.
Please check with your local authority all are different.
Alternatively speak to a service offering plan design, best place to look is under architectural services in the yellow pages rather than architects who will want to design you a castle and charge around 75-100% more!!!
Thanks for your help. The porch is existing and I have now been told by the planning dept that it has to be included in the 70m3. If I want it in writing I have to pay £55 and submit a plan!
Which local authority is that because that doesn't sound very fair! seperate pd's should always remain seperate, the local authorities i deal with do not consider the 70m3 to be the complete area of all pd's your also allowed to build a garage on your property (most local authorities) without planning permission, would that mean that they would want you to include this within any 70m3!!
London Borough of Hillingdon. I can build a garage as long as its not within 5 metres of the extension.
