Maximum drainage pipe fall for rainwater
22 Dec 2015
I'm installing ACO channel drains for a new patio. There's a rainwater drainage pipe nearby, but it's about 800-1000mm deep. To connect directly, I would need a really steep fall (much more than 1:40). Is this ok for rainwater, or is there another way to connect it? I'm worried about blockages due to the fall being too steep.
The ACO drain is running parallel to the drainage pipe and probably about 1-2m away. I'm have a small ACO sump unit, so an outlet will come out at 90 degrees. I'm planning to turn the sump unit outlet at an angle so that I don't need such sharp bends.
I guess you mean: much more than 1:40 ?
Personally I can't understand why a steep fall would increase the chance of blockage - generally a stream might block but a waterfall won't.
Yes, I've updated my original post (y)
I believe solids can get left behind if the water flows too quick due to a fall that is too steep.
Drop shaft is the way to go
So an inspection chamber?
I generally don't like having more inspection chambers, but if I put it in the right place then I could have my other drain pipe feed into it and they will then be roddable.
I've noticed that the plastic inspection chambers don't have holes near the top. Can I use one of those and drill/cut a hole for drainage pipe entries? Or would it need to be brick built?
For purely rainwater, I'd skip the chamber and just make sure there was a leaf guard in the end of the ACO.
If you use a chamber, yes you cut your own 110mm holes in a plastic riser at the height you need, then fit a blank in the pipe. The drainage would go into the chamber base via the backdrop, not just pour in from the top hole which would be noisy and a bit rubbish.
I've realised that the over-priced ACO sump unit is probably useless. The cut outs at the bottom of the channel drains are around 68mm, which means I probably wouldn't be able to get my hand or tools into the sump, which is 110mm.
What would be the best option for this pipe? Do a steep angle straight from the drain to the main drainage pipe or drop straight down from the channel drain and then have a 90 degree bend and a 1:40 fall?
Not an issue with just .water but solids can very definitely build up where the flow is not nice and smooth: we had it on a new build some years ago where flow from a side branch can into a chamber too fast and stuck to the opposite side of the base`
So I think, I will probably go for either a steep pipe directly into the main pipe, or a vertical drop and then a 1:40 fall to the main drain.
Would building control be happy with these approaches? As this patio and drainage is part of an extension project they may inspect it.
