Morning All
Im not an electrician but had one look into this issue last night and coming back tomorrow but was after a little advice/suggestions.
One of the MCB for the lighting circuit in the kitchen is tripping. The power feed comes direct from the MCB into a junction box where 3 sets of lighting are fed from. The electrician tested this connection and removed each of the 3 wires one by one and found that when the kitchen/outside light feed was removed from the junction box, the MCB was fine and didnt trip. Other lights are set 1 (single light in garage) and set 2 (3 x 240v downlighters in utility room)
Kitchen lighting is 10 x 240v downlighters (GU10 type). On the same feed are three outside lights (1 lantern style, 1 floodlight and 1 fluorescent round light).
The MCB seems to be tripping even if the lighting on this circuit is turn off and not used. Electrician seems to think it could be:
1 - Something has eaten through a wire (lots of evidence of rat droppings in loft space!) although couldnt see anything visible when looking last night.
2 - Something has got wet and causing an earthing issue (assume more the outside lights)
3 - Problem with one of the bulbs although not sure how if not turned on.
Any suggestions/help appreciated before I go mad!!
Also, the loft space above the garage is accessible but above the kitchen is a bedroom and bathroom so not sure how I can see broken without starting to pull up floorboards!!!
Thanks, Karl
Thanks, Karl
