Hi all, me again
Currently my megaflo 22 mm output goes a roundabout route to my bathroom and is around 12mtrs in length.
Once it gets to the bathroom, it goes down to 15mm and feeds a basin about 1mtr away and a shower about 2 1/2 mtr away (making shower nearly 15mtrs away from megaflo).
I want to take the pipe in a much more direct route which if I T from near the megaflo, will only be about 7 to 8mtrs to the shower mixer.
The megaflo instructions say ideally the output should be in 22mm with short runs in 15mm to taps/showers.
The question is, how long is a short run? If it's possible (as I already have the pipe and fittings) I would like to do the whole 7 to 8mtrs run in 15mm.
It's going into a triton mixer.
Currently, if I turn on a hot tap in the sink or bath (bath being replaced with shower enclosure) the pressure is very high, just like the cold, where if I open the tap too far, it comes out with such force, it goes everywhere.
That being the case, and me no longer having a bath to fill, do you think I could do the whole run in 15mm or would it be better for me to buy a couple of lengths of 22mm and do the first 4 or 5mtr in that?
Many thanks
Many thanks
