breezer said:try it and see.
breezer said:i am sorry you think so, but it depends on where you take /send it to, hence try it and see
(AFAIK, i can get it done at work for free)
mapj1 said:If its your money you might be wasting, then it is worth a quick pre-calibration check to guarantee a formal 'pass'.
Unless it says otherwise the test voltage it produces should be 500VDC, you can check that with another meter on DC volts. If you buy some high wattage 1 megohm resistors from RS or similar you can place these in series/parallel combinations across the terminals to get 500k (2 in ||) (1 meg, one on its own!) and 2meg (2 in --) .
For this investment of under a fiver you can now check the calibration against these known "transfer standards" ( the official name for a secondary standard that is not an official standard itself) any time you like between initial calibrations.
(If at any time you find the two resistors don't read the same as each other, it is time to replace them.!!)
Of course if 'official' calibration is free then there is no point, but to have such a confidence test 'in the bag' allows a defective instrument to be spotted quickly. -For the price of an official cal, you can buy many hundreds of 5% or better resistors that will stand 500V !
Regards M.
breezer said:what make of multi meter, and when was it last calibrated?
breezer said:so if it is a cheapo one (i have no objections to them, they do have their uses) how do you know how acurate it is? it may be way off at one end of the scale (it may not)
like cleaning a rolls royce with a tea towel
you can not check something using something else which itself has not been checked for acuracy and expect to get a good result
mapj1 said:If you buy some high wattage 1 megohm resistors from RS or similar you can place these in series/parallel combinations across the terminals to get 500k (2 in ||) (1 meg, one on its own!) and 2meg (2 in --)
