Hi all,
Does anyone know how to access the upper innards of a Megger MFT1720?
I bought a used one about 3 years ago, it's been working fine.
I suspect I may have developed a rotary switch issue.
I found a site that shows opening a MFT 1552 for a similar issue but the 1720 is different construction.
The left rotary switch does not quite align with the label and it feels like something is not as it should be.
Intermittently it starts beeping while the switch is set to 'off' with the display showing 'off' and briefly changing to 'err 79' when it beeps. Removing the batteries, rotating the switch then re-inserting the batteries often gets it back to normal.
