    Dismiss Notice
Membrane for Soak Away
Discussion in 'In the Garden' started by Arthur2shedsJackson, 8 Mar 2014.
  1. Arthur2shedsJackson
    Arthur2shedsJackson
    12 Aug 2011
    266
    Thanks Received:
    16
    Lancashire
    Country:
    What type of membrane should be used to wrap the box and gravel on a soak awaydrain to prevent soil ingress please ? :?:
  2. Sponsored Links
  3. pinenot
    pinenot
    4 Jan 2013
    1,728
    Thanks Received:
    230
    Angus
    Country:
    A perforated membrane to allow soakaway, and I do have two sheds, now joined into one...pinenot :)
  4. Arthur2shedsJackson
    Arthur2shedsJackson
    12 Aug 2011
    266
    Thanks Received:
    16
    Lancashire
    Country:
    Will a normal weed control membrane do ?
  5. pinenot
    pinenot
    4 Jan 2013
    1,728
    Thanks Received:
    230
    Angus
    Country:
    If it's perforated, yes. An old tonne bag, like sand is delivered in, would do, just needs perforated a lid...pinenot :)
  6. r896neo
    r896neo
    23 Feb 2007
    4,767
    Thanks Received:
    780
    Belfast
    Country:
    no dont use weed fabric it is not permeable enough and so will clog much quicker. You'd be better off not using one at all.
    You need to use a purpose made geotextile product. The most common would be terram 1000 or an equivalent from another mftr. Their permeability will be many times as much as a weed fabric.
    You can buy them in small sheets usually.
    • Thanks Thanks x 1
  7. Arthur2shedsJackson
    Arthur2shedsJackson
    12 Aug 2011
    266
    Thanks Received:
    16
    Lancashire
    Country:
    Is that not technically one shed ? :confused:
  8. pinenot
    pinenot
    4 Jan 2013
    1,728
    Thanks Received:
    230
    Angus
    Country:
    You have a valid point, but I'm constantly reminded that it'two sheds stuck together! :)
  9. DIYnot Local
    3 Sep 2019
    Country:
  10. Sponsored Links
Loading...
Share This Page
