metal cuttung disc for cast iron pipe
10 May 2006
Hi guys
i need to cut a cast iron soil stack pipe with the angle grinder. Will a general metal cutting disc for steel/inox do the job or do i need to buy a specific cast iron cutting disc? Where can i buy one which is up to do job without having to fork out 30-40 quid? Thank you in advance.
Buy a disc for cutting tiles. Much better than your cheep metal cutting disc. your local Tool Station or Screwfix will be the cheepest. Your looking at around 2-5 pounds depending on the size of your grinder.
Thanks for your advice m8. I have had a look at the Macrist selection.........i was fainting...............the product must be very very good at 50 quid!!!!
I've never cut a cast iron pipe but I've cut up a couple of cast iron fireplaces using a normal metal cutting disk and it worked perfectly. Much easier than cutting steel.
