Meter checking
16 Jan 2006
Lancashire
Does anyone know an accurate way to check if my meter is correct . I have a bill of £60 per month which seems a lot for a small terrace , 2 people and GCH . I have read the meter every day over a week and according to it I am using between 17 - 29 units per day .
Dave :roll:
Do you have lots of computers and AV equipment left on standby all the time?
Is your fridge on the old side?
Do you use the tumble drier a lot?
Do you have an electric shower?
An electric hob?
A penchant for halogen downlighters?
Dave :roll:
best way is to get another meter and place inline with the existing. both should read the same
going by 17 units per day, times 28 days and at 8P/unit, its 38.8
29 units is 64.96
altho there is normally a higher rate for the first X amount. see your bill for the price
You can get it checked. Ring up your supplier. There will be a charge if there is nothing found. I think it costs around £30.
Next time you go away on holiday, or even for the weekend, turn everything fully off except the F/F, and see how much clocks up while you're away...
I did a check last weekend when we were away from home. the meter clocked up 10 units over a period of 36 hours with only a small fridge /freezer running in the house and a small upright freezer in an unheated outbuilding.Apart from the clocks on the oven and video recorder every thing else was unplugged . does this seem reasonable ?
Dave
Dave
that works out at a constant 270W being used. sounds about right, with 2 fridges
