looking at getting old 4 way wylex fuse box replaced. this is fed with i would guess 16mm tails. also a two way fuse box feeding an electric shower also fed by 16mm tails.
however, tails from the board fuse to meter look really small. would guess they may be single insulated but even so they look no more than 10mm.
i would guess a 10 way split rcd board would be going in. so 16mm tails must be ok as it seems pointless any bigger going in with such small csa tails from the fuse to the board. is this normal?
