Hi all,
I’m hoping you’ll be able to offer me some advice regarding carrying out insulation and cintinuity testing on my washing machine. I have ‘borrowed’ a Metrel EasiTest tester (which I assume is suitable) while our electrical technician is away at work in the hope that I might test the motor and element on my washing machine for possible problems.
Can you confirm how the insulation test is carried out? I assume that I'm going to use the 500v setting and that one of the leads connects to the earth and the other connects to both the live and neutral pin at the same time is this correct? Does it matter which lead connects to which pin?
Likewise when testing earth continuity does it matter which lead attaches to the earth pin of the plug and which to the component being tested?
Any advice would be appreciated. in case it helps the following is printed on each lead:
Black L1 - L
Blue L2 - N
Green L3 - PE
Yours ,
J
Black L1 - L
Blue L2 - N
Green L3 - PE
Yours ,
J
