Ive got a microbore system in my house and have rececntly changed 1 rad and fitted new valves on another as it wasnt getting hot.The rads were fed by 2 10mm pipes connecting at the same side of the rad but i was told to fit 1 pipe at 1end and run the other to the opposite side which did using compression elbows so i now have valves at both ends.The rads work brilliant but i was unsure weather i had to leave both valves open or if 1 has to be closed,they are both open at the moment.Can any one clear this up for me????
___________________________
Moderator
split from hi-jacked post
Moderator
