Microbore manifold on central heating
8 Feb 2008
Cambridgeshire
I have a manifold that reduces from 22mm pipe to 4 x 8mm microbore pipes. There is a leak coming from the exit point of the 8mm pipes. Any suggestions as to a temporary fix and also where are these manifolds available?
is it compression...ie nuts..if so try tightning it
or it solder ?
Drain down and replace the manifold.
Should be available at any major plumbing merchants.
