Miele condensor dryer (tripping electrics after repair) (Ed.)
9 Oct 2024
I have a Miele condenser dryer and I’ve recently replaced the thermostat because it stopped getting hot , it now gets hot and runs a cycle perfectly , however about 10 mins into cycle it trips the electrics of the house .
I suspect an earth issue but don’t know how too troubleshoot this , I do have a multimeter. When I took the back plate off the day after it tripped the electrics I found this moisture on the inside of the backplate, is damp getting too the element causing the trip and why is this ? It does have a musty smell when running .
Thank you for any advice
What exactly trips, an mcb or the rcd? I can't view your attachment for some reason so cannot see the moisture you mention. Is the "back plate" the rear cover. If so try running the machine but leave the cover off. If moisture is causing the problem then it should stop tripping. A faulty element is a more common cause of the problems you describe though. I doubt you will be ablle to find a fault with a multi meter as you would probably need an inulation tester to stress things. Might be worth looking at his thread below https://www.diynot.com/diy/threads/miele-t650c-tumble-dryer-tripping-out-rcd.337477/
Hi it trips the rcd on house fuse box , about 10 mins into cycle this photo is the inside of the panel where the element is , the dryer has a musty smell when running is there damp in the machine from storage or something? I have cleaned the condenser
