I have a Miele dishwasher model 1022i that has been failing to start properly.
The initial drain pump runs ok, then it stops with the drain/fill light flashing. 5 short and 1 long flashes. It will drain fine if I throw a bucket of water in there.
I fitted a new partition kit - the old impeller had fallen apart. Then a new overflow microswitch (the old one got wet and short circuited).
Then I gave up and called Miele, fix price repair. They replaced the water meter and the heater pressure switch. That didn't fix it so they came back and replaced the circulation pump (complete with another partition kit and heater pressure switch), and then the internal water inlet solenoid. Still didn't fix it.
The engineer was a bit stuck at this point and has arranged for a third visit, where he'll fit a new inlet hose/aquastop.
I'm not confident this will fix it. Does anyone else have any ideas I can pass onto him, as he will have replaced most of the working parts by now I'd like to keep the machine rather than having it written off!
What does the 5 fast - 1 slow light actually mean?
Thanks for your help.
