- Joined
- 23 Nov 2026
- Messages
- 1
- Reaction score
- 0
- Country
I'm posting this as a complete text-only write-up, since pictures in old threads often disappear over time. Everything you need should be in the text below.
APPLIANCE
- Miele T 8633 C condenser tumble dryer (SoftCare System, Navitronic display)
- Type: HT17-2
- M-Nr.: 06757450
- 220-230 V ~ 50 Hz, 2.65-2.85 kW, 16 A
- The rating plate is behind the door, on the front panel below the door opening.
SYMPTOM
At random moments the dryer stopped and the display showed a warning triangle with "F4" and the text "Technical fault - Contact Miele" (on my Dutch machine: "Technische storing - Neem contact op met Miele"). Switching the dryer off and on again cleared the fault and it would run normally, sometimes for several cycles, until it happened again.
WHAT F4 MEANS
On Miele dryers, F4 means an open circuit at the drying-air (process-air) temperature sensor, an NTC thermistor. In the Miele diagrams this sensor is component 1R30. Note that F4 means something different on Miele washing machines and washer-dryers, so don't mix up the code lists. On dryers, F3 is the same sensor short-circuited, and F1/F2 are the second NTC at the heater (2R30) short- and open-circuited.
An intermittent F4 therefore means the sensor circuit is opening intermittently: in the sensor itself, at its connector, or in the wiring to the control board.
CONFIRMING IT IS THIS SENSOR
1. With the front panel off (see below), I unplugged the sensor connector and switched the dryer on. It failed immediately with F4. So F4 is definitely triggered by this sensor circuit.
2. With the sensor plugged in and the dryer on, I wiggled the sensor wires and the connector. This did NOT trigger F4. So the wiring loom and the plug connection are less likely to be the cause. The break is more likely inside the sensor housing, for example a cracked solder joint or a thermistor lead that only opens under certain conditions (heat/expansion).
THE SENSOR
- Make: EPCOS (now TDK)
- Marking on the grey plastic connector housing: "EPCOS", "6", "T-Nr. 3523183"
- 3523183 is the Miele part number.
- Construction: grey plastic plug housing with a stainless-steel probe sleeve, held in a rubber grommet.
- Location: front of the machine, in the middle, between the two removable fluff filters at the bottom of the door opening.
(For reference: an older UK thread about a Miele T 294 C with F4 used part 3523184 for the front NTC. Check the number for your own model.)
TOOLS
- A long Torx screwdriver. The front screws sit deep inside the plinth grille, so a short bit won't reach.
- All the screws on this dryer are the same Torx size. You can find the right bit by trying it on one of the easy-to-reach screws on the back panel first.
- Optional: a multimeter, to measure the sensor.
DISASSEMBLY - REMOVING THE FRONT PANEL
WARNING: unplug the dryer from the mains before you start.
1. Plinth (bottom bar): at the very bottom of the front there is a white plastic strip with horizontal ventilation slots. There is one screw at each end, left and right, inside a round hole. Remove both screws and take the strip off. Good moment to clean the fluff out of the slots.
2. Behind the plinth there are four screws in a row. Remove ONLY the two outer ones (far left and far right). The two middle screws only hold a small metal plate and don't need to come out.
3. Open the door. Around the round drum opening there are five screws in the front panel. Remove all five:
- top left of the opening
- top right of the opening
- lower right, just above the rating plate
- bottom centre, directly below the opening
- lower left, near the lower door hinge
Do NOT remove:
- the screws of the two door hinges (left side)
- the two screws of the door lock / catch (right side of the opening)
4. Taking off the panel: the front panel now hangs only from its top edge. Push the panel up slightly, then tilt the bottom towards you and lift it off.
CAREFUL: the door lock (component A2) stays attached to the machine by an electrical cable AND a mechanical release cable, so the panel cannot be fully removed.
- With the dryer standing on the floor, rotate the panel 90 degrees anticlockwise and rest it on its left-hand side, with the door open. That gives just enough room to leave the lock's electrical connector plugged in. Alternatively, unplug that connector.
- I found no easy way to detach the mechanical release cable, so either way the panel has to rest on its left side next to the machine.
REMOVING THE SENSOR
5. Remove both fluff filters from the bottom of the door opening. The sensor is in the middle at the front, between the two filter positions.
6. Reach in from behind the filter position and push the sensor with your fingers so it tilts slightly in its rubber grommet. With the sensor tilted, the connector is easy to pull off. Then push the sensor further to get it out of the grommet.
Note the orientation: the sensor sits in the grommet at a 45 degree angle, running from left to right.
7. Reassemble in reverse order. Seat the sensor firmly in the grommet at the same 45 degree angle and push the connector fully home. A connector that isn't fully seated can itself cause F4. In the old T 294 C thread, a new sensor didn't fix F4 until the plug was reseated.
WIRING DIAGRAMS (FOUND INSIDE THE DRYER)
There was a folded A3 service sheet inside the machine:
- Circuit diagram (Schaltplan), sheet 06177451, titled TR "Adonis" / "Novo IV Plus Facelift"
- Wiring diagram (Verdrahtungsplan), sheet 06177471
- Component legend in German/English/French/Spanish, Mat-Nr. 04933441 ("Legende HH-TR ab Novo III")
Relevant designations from the legend and diagrams:
- 1N1 ELP = electronic control board
- 2N1 BAE = control panel electronics
- 1R30 = drying-air temperature sensor (the F4 sensor). It has its own two-wire connection to 1N1 ELP and is drawn at the front, next to the door lock.
- 2R30 = second temperature sensor, at the heater (F1/F2)
- R1, R2 = heater elements
- F1 = thermostat (on the heater)
- A2 = door lock
- B3/1 = residual moisture sensor
- B8/7 = float switch, condensate
- H3/6 = drum lamp
- M5 = drum drive motor, C5 = its capacitor
- M13 = condensate pump
- K1/1 = heating relay
- S1 = selector switch, S2 = on/off, Z1 = interference suppressor
If you're working on the same model and need the sheets, ask in this thread. (They're Miele copyright, so I'm not reposting them here.)
STATUS (KEEP AN EYE ON THIS THREAD)
I removed the sensor, cleaned it and its connector, and refitted it. I'm now waiting to see whether F4 comes back.
- If F4 returns, I'll replace the sensor with part 3523183 and post the result here.
- If it stays away, a poor contact at the connector was probably the cause after all.
TIP FOR DIAGNOSIS
Note how far into the program F4 appears. If it only happens once the machine is hot, that points to a thermistor whose internal joint opens as it heats up. That would also explain why wiggling the wires on a cold machine didn't trigger anything. You can test the removed sensor with a multimeter: measure its resistance at room temperature, then warm it gently with a hair dryer. The reading should drop smoothly as it warms. If it suddenly jumps to open circuit (infinite), the sensor is faulty.
Questions welcome. And if anyone has cured an intermittent F4 just by cleaning or reseating the connector, I'd like to hear it.
Attached the same guide with pictures.
Happy repairing to all.
APPLIANCE
- Type: HT17-2
- M-Nr.: 06757450
SYMPTOM
WHAT F4 MEANS
THE SENSOR
TOOLS
Do NOT remove:
REMOVING THE SENSOR
- A2 = door lock
- H3/6 = drum lamp
TIP FOR DIAGNOSIS
