Thanks for the above replies. So here comes the detail: I noticed that there was no spin cycle during the rinse stage and also at the end. It was not possible to turn off the machine and the 'finish' alarm continued. By opening the door and closing it a bit more forcibly the led went out and the selector switch was returned to 120'clock and turned off. Thereafter a 60deg. wash was done and again no spin apart from the initial 400 at the start. However, a separate spin cycle worked fine. Subsequently, there was an exponential deterioration in the process. Prior to next usage, the drain pump, hoses were all checked and as expected all very clean: I had cleaned this system and examined it previously during a condenser/ leak tray fault. I also examined the plenum connected to the drum and the hose to the pcb that is the basis of my question, all was clean. Subsequent use resulted in inability to turn off the program, so on turning the machine on and when the door was latched the finish alarm would sound and the drain pump run as thought attempting to finish the previous wash cycle-the selector still being at 12o'clock. Testing of the door relay showed it to be working correctly.
I bought a used washer on ebay that was sold for parts and not working and changed the pcb that is the basis of this thread. A trial this morning showed that only the led for on was indicated-as opposed to the earlier scattering of drain final rinse end of programme indications previously. A 60deg cycle has run through with an apparent increase to 1500rpm9I thought it only ever operated at 1200 unless selected). Alarms cancel at finish and on a trial of this and fluff removal, we seem to be fully operational again.
So why ask? Well the ebay washer will be a similar age and hence the fault might reappear-we are talking 12 years old. I want to determine the component fault rather than doing a substitution as so many of our technicians seem to do ( with the edifying finale of cost of call out time and part replacement cost and finally having parted with the cash and suspecting they could probably only guess at the failure tell me 'it's not worth repairing..'
Finally, testing the pressure switch: it's often said that if you blow down the spout into the switch/diaphragm and don't hear a click it's failed. Neither mine nor the one on the replaced board do so. There are four terminals. The switch is made by Miele.. Looking forward to hearing from you and further on fault trees, reliability and problem solving.
