Mila Door Handle Problem
15 Jul 2017
Hi, we have a Mila Door Handle similar to
http://www.mila.co.uk/Portals/0/ProSecure handle literature web.pdf
I'm struggling to remove the handle, I've removed the two large retaining screws but for the life of me can seem to figure out how to remove the handle. The inside handle has a small screw or something in the handle itself but I cannot seem to find out how to remove it.
Any ideas? THanks in anticipation.
Lee
Its probably a tiny grub screw and normally need a tiny Allen key like a 3mm, it could however need a flat bladed screwdriver, can you take a photo?
Thanks crank. It looks like whoever fitted the handle initially overtightened an Allen key screw. Got any advice on how to loosen?
Well if it's rounded and still stuck fast then you'll need some easy outs, if not then driliingmit out is an option but you'll need a replacement grub screw if you do, if you drill the middle out these tiny screws just crumble and fall out
