Minimum thickness for cavity wall
  • Thread starter Thread starter cdh
  • Start date Start date
cdh
22 Apr 2006
West Midlands
We are having an extension built and have been told that we need to have a cavity wall built between the kitchen & the garage. Due to tightness of space, what is the minimum thickness of wall we could get away?
You don't need a cavity wall.
You need a wall to provide sufficient thermal insulation and fire resistance. A 100mm timber stud wall with celotex/kingspan insulation and then 12.5mm plasterboard and skim both sides will do it, but the BCO may want an additional 25mm of insulation across the inside face of the timbers too.
So minimum would be 150mm, possibly 125mm
