Mira element shower scalding hot
15 Mar 2008
Merseyside
Just moved into a new house and replaced the old boiler with a new Ideal boiler.
This has made the mira element shower run scalding hot.
Is there anything I can do or do I need a new shower now?
There has to be a way of mixing the water, either on the shower or at the taps depending which model you have.
Have you checked you are getting a cold supply as well as a hot?
Hi Conny, thanks for your reply.
The instant you switch it on it is boiling hot, do you know if there is an adjuster inside ?
