Hi all,
I have a Mira Event XS Thermostatic power shower. It has recently developed a problem where by it takes 10 mins or so after switching it on for the water to start flowing. I can hear the pump running but nothing comes out.
Also after turning off the shower the water still flows. It usually stops after 3-4 mins but today it wouldn't stop so I have had to turn off the hot water.
I have done some reading up on it and it sounds like the problem is the solenoid valve based on these symptoms. However, I have checked the resistance of the coil and it reads 3.36kohms which is only slightly under the required 3.4kohms, so now I have some doubts if that is the problem.
Do you think it is the solenoid valve?
Any help greatly appreciated.
Thanks,
Andy
Thanks,
Andy
