Would you just put it on the top (tapered) surface of the rubber cone
I cut my own washer from an offcut of rubber. The cone going into the hole does not work as well as a flat washer as large as the plastic nut.
You roll Mait into a snake and make a donut type washer.Well, just for the amusement of all gathered here, I’ll continue to report… so I got a tub of this Mait stuff. First problem (for me anyway) was that its consistency was MUCH stiffer than I expected, and I found it very difficult to work with, squeeze into tight gaps etc.
Second was how to get it off my hands afterwards… soap & water it says on the tub? I scrubbed and scrubbed, but it didn’t touch it. Neither did meths, and I was heading out for a de-stressing tea & cake afterwards, so didn’t want to reek of white spirit – maybe that would have done it.
Anyway, everything’s gone dry again… for now… watch this space…
To stop it sticking you can wipe it with a little washing up liquid.
The best thing to clean mait up with is the product itself... Keep it moving and rolling and you can use it to mop all the other bits up... Did you never play with plasticine or slime?![]()
There was 32 of us living in a shoe box int middle ot road.Eee, sonny, didn't have none of that slime in my day (except in't duck pond), and we were too poor to afford plasticine, we had get up in the morning at 5:00, half an hour before we went to bed, eat a handful of cold gravel for breakfast, walk 24 miles to mill AND pay t'mill owner for permission to go to work, and when we got home our Dad would thrash us to sleep w'is belt - if we were LUCKY.
I didn't mean play with it "as a kid"![]()
That's why I never use mait, horrible stuff, especially when you have to take things apart.
A little bit of silicone goes a long way in these circumstances.
Just need to be careful, too tight and you can deform the seal.
For me it's a little fill of silicone into the gap around the waste body and throat of the basin underneath & a fillet of silicone on the back side of the washer. Fit the washer and press it up and in and the silicone that squeezes out at the thread, smooth it around the thread and the washer. Then the basin waste nut goes on and gets hand tightened then no more than 1 turn with a pair of large pump pliers. Then smooth in any silicone that squeezes out into the inside thread at the nut and the outside of the nut to seal it all up.
Leave it for half an hour and bobs' yer auntie's bit on the side
