MIXER TAPS
19 May 2005
Cheshire
Can i run mixer shower taps from any system ie direct---- indirect if not why not
thanks for help
I want to put a mixer shower on the bath i have old fasioned system with cold water storage in attic i got told cant use mixer taps as if cold water goes out i will get scallded
i.e, wots indirect, wots direct, central heating, bog, shower..... :shock:
Do you have central heating.... or do you have an immersion heater that justs heats up your hot water??? do you have a big white thing in a case, probably in the kitchen perhaps....?
wanna give that another go slowly
you mean if the cold water runs out :?:
if so that is why you tap the cold lower than the cylinder feed :idea:
Don`t think he needs a plumbing lesson ... he won`t have understood a word of your last... If you can post again bro, & tell us what goes where we`ll get it sorted :D :D
Sorry, Did I say `we` I meant `I` :D
alls i want to do is fit mixer taps, i just want to know there will be no problem yes i have central heating i have a big storage tank in attic and cylinder in cupboard
You need a low pressure mixer, with the cold coming off the tank in the loft.
Should be no problem if your hot pressure is up to it. :D
A mixer might not be the best idea.
Not enough pressure to get you wet if the tanks in the attic are just a few feet above the proposed height of your shower head.
Fit an electric of the rising main.
