Hi All,
Can you please offer some advice on whether it is advisable to mix plastic and copper pipe and fittings. My prediciment is that i want to tee into my cold water supply feed (copper) coming from my cold water tank in the loft (this feed runs to the cold bath tap).
I wish to tee into this length of copper pipe in the loft space with a 15mm plastic "tee" fitting and then use plastic pipe to take to a pump and connect to pump with flexi.
Is it advisable/ethical to combine a mixture of copper and plastic? Has anyone had any good/bad experience with this?
Your continued help and advice is much appreciated.
Many thanks
Mark
Many thanks
Mark
