Modern Toilet Advice
25 Nov 2013
Fife
Considering replacing 1980s old loo with a close coupled flush to wall one.
Mid point of soil pipe is approx. 150mm from wall. Can anyone give me any ideas as to loos which might fit. Any recommendations for modern loos which give a decent flush?- not looking for a loo with a small flush volume. Currently considering Ideal Standard Concept Cube 6l flush but no idea if these are decent toilets or not.
A good plumber can and will find away to make it fit.
You need to look at the technical information supplied with any toilet as to the size and dimensions (search the web for the loo of your choice).
Position of the soil pipe may impact on the final look, I assume from your post the pipe comes from the floor not out of a wall to the side or back.
If it is buried in the floor you may need to box the wall out behind the loo to make it look nicer, or spend some extra money having the pipe moved to the right location.
unfortunately not white- the colour of the loo in question is a delightful shade of turquoise! Not the prettiest.
