Monitor screen peculiarity
7 Mar 2016
Ireland
Hardware or software - I dont know?
Anyway, what happens with the picture on my monitor screen is that it might not achieve perfect resolution for a day or two.
For example: I click on a OP's posted pics, and they seem fine although the detail is not the clearest, but satisfactory.
Then I return to the image say, a day or so later, and suddenly more specific detail is being illustrated.
Its as though my system is taking its time to develope its full "resolution"?
Any thoughts?
danechip,
Thanks for replying. I will attempt to sort the driver business with a little help, and come back with how successful its been.
stevethespreader,
Thank you for replying. Thats a good question. I dont view many still pics outside of diynot.com mostly I only watch vids on youtube and detail is irrelevant.
I'll check from this evening and let you know what happens.
Thank you both again. For the time being it appears to have resolved itself - all I did was wait, I was too scared to attempt to mess with the drivers, and other sites & browsers were fine with the issue.
So its back to seeing how long this will hold up - digital fingers crossed.
Thanks again, although I'm no further ahead in finding the cause, at least I'm not going backwards.
Neil Henry,
Thanks for your advice.
MY internet speed is average for my area, & I constantly empty he cache. Whatever a "paging file" is my PC doesn't seem to know, and I know far less than my PC but I will ask someone local who claims to have digital knowledge. Thanks again.
Neil Henry,
When I said Internet experience that's what I meant , just because they say it's a certain speed do not mean that you are getting that speed ,especially when everyone's online all at once, if your band width is strangled you may not get the full experience it happens on my phone sometimes,fwiw I am supposed to have 50 mbps on Virgin but there is a fault in the area "so they say" but I think they have not upgraded their system to cope with all the people on line they are currently giving me a partial refund till its sorted it could also be your browser or diy not itself
Thanks. Interesting possibility.
As for diynot itself, they told me that some other difficulty I have on here is due to my not allowing cookies - I dont allow hardly anything but the minimum necessary to access a site. If it comes down to loss of resolution or getting a bug then I'll put up with the resolution business.
I guess that I'll wait and see a bit more.
Sounds like your browser is not loading the image properly. For example it my be showing a low quality cached (stored on your computer) image, and not loading the full size image for any number of reasons. If it does occur again, go into your browser settings and clear your cache. It will save space on your hard drive, and hopefully remove any faults relating to that. The cache is stored files from browsing, used to speed up loading times when you revisit Web pages. It is not uncommon for cached files to conflict with new pages you view. If you do clear your cache, you may find you might have to wait a second or two longer for the page to load. This is a software problem too.
What is your browser Vinn, and do you have the same issue if you swap to another browser What operating system are you using, and o you have any AV software installed.
Internet speed won't be an issue, and youtube videos are low resolution, so you wouldn't notice a lack of resolution there. Clearing the cache won't achieve much in this sitation, and whilst it might be a driver issue, if you're running windows 10, then it might be down to a recent update automatic update, so if changing the browser doesn't resolve it, you may need to start reversing the recent updates.
So a 1080p or 4k YouTube video is low resolution? How wouldn't clearing the cache help?
Ah, I haven't been using them at that res, so thanks for that; I knew Netflix was running 4K, but didn't know that YouTube was doing it as well.. But Vinn needs to check the resolution of the videos he's watching, as that'll throw another factor in. If the browser can display a 1080p video, but not the pictures from diynot, then that suggests it's the site that's at issue. And as there have been problems with the links etc on the site, it could be coming from the server, and not his computer. He needs to run a few comparative tests, and see if there's a constant theme, or where the differences are.
The caveat here, is that a video is a constant moving picture, so may well have problems, but his eyes aren't noticing the difference.
A cache is designed to hold things for frequent use, so that it's there if you need it again; as you've said in your earlier post, you only need to clear the cache if you've got disk space problems - If the image is being picked up from the cache, then it'll always go there first, so it should be constant. And if there was a disk corruption in the cache area, then that would cause disk read errors, not improvements over time.
