Hi Folks
Hairyjon back again! Thanks Comms for your previous. Unfortunately the 2.5 mm T&E shed radial is not long enough to break into without cutting the cable and replacing it to the shed with a longer length to allow fitting of an FCU. As I intend eventually to use this as a lighting radial with a 6A MCB in the CU should i start from scratch and replace the cable from the CU with 1.5 T&E as appropriate for a lighting circuit or is it acceptable to move the 2.5 from its 32A MCB to one of 6A rating if it will reach and then use 1.5 mm from the FCU?
P.S. How does one use smilies? I'm not very good with IT!
