Hi all
Re Potterton Performa 24 combi
After getting the PHE cleaned a couple of months ago - it was full of limescale - the water is again not getting properly hot. Problem is as follows:
Turn on HW tap, boiler fires up and heats the water. Burner then goes off (as expected), but takes too long to come back on again. Result being water goes cold before being heated again. So hot-cold-hot etc. [Although when i say hot i really mean only warm!]
In the period when the burner is off the boiler makes a kind of ticking/whirring noise - it's as if it's trying to fire up but can't. I'm by no means an expert, but surely it can't be the PHE again? Could be diaphragm i guess - last time i changed it was about two years ago - but boiler has no problem firing up when tap is first switched on.
What do you guys think?
Cheers.
Cheers.
