Thanks for your opinion. As you will have seen, there are a variety of opinions on this issue.In my opinion, the reg has no ambiguity and the commas make it's requiremnt quite clear.
I don't fully understand what you're saying there. If the meter does represent an electrical interuption (i.e. no electrical continuity across it), then a 'bond' attached after the meter would not fulfil the function of Main Protective/Equipotential Bonding. Like you, I don't know whether meters always/sometimes/never represent electrical interruptions (and I doubt that one can guarantee that the same is, and always will be, true of all meters).In John's first post he stated it as an either or scenario. I don't know what is inside a meter, but asuming that there are insulating parts inside would make bonding after the meter an understanable proposition.
Why are you confused? Do you disagree with my statement? If so, perhaps you can explain why.I am a bit confused by John's quote
'Are you not overlooking the (one and only) reason for main bonding - namely to prevent a PD arising within the house by virtue of a difference in potential between the house's MET and the potential introduced (from outside the premises) by an incoming service pipe?'
As far as I am concerned, the one and only purpose of Main Protective/ Equipotential Bonding is to ensure an equipotential zone within the premises - which is achieved by ensuring that there are no 'touchable' parts within the premises which are at a potential appreciably different from that of the electrical installation's MET. The only thing which can compromise that equipotential zone is an extraneous-conductive-part (as defined in regs) which enters the premises. Bonding them to the MET minimises the PD (relative to MET) which they otherwise might result in. Bonding anything which is not such an extraneous-c-p (such as a water service pipe after an insulating interruption) does nothing to produce/ensure an equipotential zone, as is therefore not MPB/MEB. Do you disagree with some/all of that?
Kind Regards, John
